So I've done what I can so far and Still cant get my spree running. This is my 2nd spree that ive got up and running from scratch but I just cant get this one to fire.
Heres what i've done.
- Cleaned carb, numerous times, carb is getting gas
- Checked reeed valve - fine
- Spark Plug - getting spark and have replaced with new plug
- Replaced rings and piston
- Spark plug is getting wet smells of gas
- wont start of starter fluid.
Any ideas?
Spree Not Starting!
- scooterwerx
cody_maasen
- scooterwerx
yup, there's a neat article about re-surfacing the float-valve seat in the tech documents somewhere...involves Colgate. That might help ya. Definitely sounds like your float valve isn't working correctly. May need to replace it.
1986 Honda Spree - Running amazing.....body work still needs to be done, but that's a Spring job.
Stuck Float
Search "minty-fresh".
cody_maasen
So since I thought it was the carb I went and switched the bystarter and carb off my good running spree and put it on the scooter. Still wont start! Has spark. Has compression. Something I just rememebered however was that when I got the engine for this scooter the black piece/part (dont know name of it ) below the magneto/cdi was bent up so it was blocking the peice from turning around correctly. I bent it back down. Could I have bent it to far and changed the ignition timing. I have an extra one I just dont want to replace it if its nothing to worry about.
cody_maasen
getting it started
I 've two areo that doesn't start. I have the same thing going on getting spark air and fuel. I havn't check the reed valves yet on both. the year before last the one that I was riding kind of got hard to start. And I knew that when I got it out of storage that it wasn't going to start. just don't know for sure what to do. the other one I bought for my wife and it wasn't running when I got it. So if you get yours going let me know so that I will check it on both of mine
