Polini 65 kit, 0.5mm carbon reeds behind cleaned-up manifold, K&N filter, Leo Vinci 4447 pipe. Drilled Polini jet to 90-ish. The plug was paler than Nestle's Qwik, temps hovering near 300, iffy power with prolonged WOT.
I suspected lean mixture and overheat was the issue. Tonight I installed a 95-ish and it was markedly better. No power trail-off after 45 seconds WOT and a shade darker plug. Think Fry's cocoa.
Speed is back to high 40s with 7.83:1 gears, which is what it was with stock 11:1. No hill necessary to reach that speed, which arrives fairly quickly, then the RPMs abruptly decline as the variator goes full overdrive. The new thing is I can cut throttle to roughly 2/3rds and still maintain over 40.
My only remaining issue appears to be the 8g variator weights, which arrived from China today. Still too heavy, it seems.
I should receive my new $25. OKO tomorrow, and will try 7s to start. Suggestions welcome.
This concludes our broadcast day.
