Is it correct thinking that a vacuum operated fuel pump would pump MORE liquid as you increased RPM?
http://www.mikuni.com/fuel_pumps/fuel-pump-df44-211.jpg
Just brainstorming.
Fuel pump pumps water into small jet(like a old idle jet or something) blowing into the airbox LID. Air filter atomizes water, pump feeds more water with more RPM, Spree goes faster.
Water injection
Water injection
for water injection to be effective,you have to use a high pressure pump to spray into the manifold.on cars we use the 150psi pump for the na and turbo engines.it itomizes better and we also use a alcohol water or methenol water mixture.cheapest is the windshield washer fluid from walmart.it is triggered by either tps switch or pressure sensor switch.in the scooters case you would have to use a manual switch or pulse sensing switch for every spark pulse.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
91 yamaha tzr 250r
Re: Water injection
it accually wouldn't go faster but it would keep the cylinder cooler and clean the piston and exhaust port.with water injection you can run a higher compression without the engine getting hotter and with alcohol or methenol add it raises the octane rating.Kenny_McCormic wrote:Is it correct thinking that a vacuum operated fuel pump would pump MORE liquid as you increased RPM?
Just brainstorming.
91 yamaha tzr 250r
91 yamaha tzr 250r
- burnt_toast
he actually did pull it off on his early SE builds, and claimed it worked quite well saw gains in midrange when activated but mostly what baka said, its meant just to cool engine more.Dac wrote:DioSpeedDemon tried this a while back but didnt get anywhere with it. I think its a good idea but its extremely hard to pull off.
but he never saw gains on his dio builds..
I was very interested in this a while ago and talked to him quite a bit.
projects galore
Water injection
I don't think water injection won't work on a 2 stroke. cause it will mess up the airfuel ratio, also 2 stroke relys on oil mixed gas to lubricate the crankshaft and the con rod, 2 strokes don't have and oil sump like 4 stroke scooters....
