how to make an iowa spree run over 25
- circusracer
- Goped
Yes they will fit. With the domed 86 piston and the shaved 85 head you will notice much better acceleration.forewheelerdude wrote:thanks for all the info. GREATLY appreciated! also one more question about the differences between the 85 and 86 heads- i was wondering since i already shaved .020 off my 85 spree if the whole sleeve head and piston would fit on my 86 spree?
84,85,86 sprees: Intake mod, drilled pipe, .020" milled 1985 head, dome piston, 2mm raised exhaust port, sb50 reeds, 34mph average.
- circusracer
- Goped
LOL, you beat me by two minutes Kenny, I need to learn to type faster.Kenny_McCormic wrote:A late piston and early head will produce the best results according to noiseguy. Just check your clearance if you go that way with the shaved head.
