Help!!
deanald
Help!!
Post by deanald »
My scooter runs great, except when starting cold. It will idle, but once you give it gas it just dies. But, once you manage to get it up to full speed for so much as an instant, it runs perfectly. Am I just completely inept at controlling the air/fuel mixture, or is there something bigger here? I don't think it could be the bystarter, because it takes a significantly longer time to heat up, and the scooter idles fine if i manage to get it running quickly
Please help, this is my senior project and it would be embarrassing if i made assurances that it ran perfectly and then it died when i gave it any gas
Thanks!!
c:
Post by Kenny_McCormic »
the bystarter being bad makes it run like s*** once it gets hot. Clogged passages in the carb related to the bystarter make it run like s*** cold.
deanald
Post by deanald »
but all i need to do is get it up to full speed for literally an instant before it will run perfectly. I would doubt it heats up that fast?
c:
Full speed is about 8000 explosions per minute, pretty hot eh? On my old Kaw F-11 250 you kick it and the second it catches flip the enricher to run, it will not run right with the choke on no matter how cold it is.
deanald
Post by deanald »
huh. yeah that would make sense
so what passages would be "related to the bystarter" then? I felt like i've cleaned it out pretty well. If the problem is for sure in the carb though, i could get a lot more intense about it 8)
c:
toboggan
Post by toboggan »
http://www.hondaspree.net/phpBB2/viewtopic.php?t=8786
I'd do that, and clean each part with spray carb cleaner, or dip carb cleaner
deanald
Post by deanald »
alright, i'll try going through it again
8)
c:
