24 vs 28
gsxrg
24 vs 28
Post by gsxrg »
Just wanted to ask the experts. how much differance is there in a 24mm carb and a 28mm carb? This would be on a 72cc honda motor. Looking at top end speed. how much faster would it be?
Thanks in advance
Too Much Carb
The Collective requires more information about your setup to answer precisely.
See Arreche 17.5 thread. Unless you port and open/tune exhaust, adding more carb does not always add speed. Sometimes it works against you, and makes part-throttle riding unpleasant.
In my case, the 17.5 is not the limiting factor to Flash's top of 60+. There's only so much 65 or 72cc can do...
YMMV
burnt_toast
Post by burnt_toast »
like wheelman said, depends on overall setup
projects galore :nerd:
maddog
Post by maddog »
on smaller carbs you can mill the rear of the throttle slide 1ml. at a time ,thats old school.
