WOT woes
kho20
WOT woes
Post by kho20 »
okay the problem is the lil spree starts fine decent accel hits right around 30 and then loses power feels like the bowl ran out of fuel, so i let off the throttle and hit it again fine for a second then does it again...also it only does this at load on the stand itll rev all day
i have the petcock drilled because it was workin off and on and * me off when i was tryin to tune the carb :evil: ... i jus havent got around to installin the maunul shutoff. and as for the bystarter i kinda broke it so im pretty sure it don't work
so my question is do yall think that this much fuel flowing to the carb could be causing the problem or does it sound like a float needle/seat problem or somethin with the bystarter?? :?:
bakaracer
Post by bakaracer »
Is the filter clean?what is the air fuel screw adjustment?How many turns out?how does the spark plug look?
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
kho20
Post by kho20 »
filters clean , both mixture screws at 1 1/2 to 1 1/4 out, and plug chop shows white tan
84 spree: dont kno what im gonna do with it yet
82 v45 magna
97 dodge 12v dually
87 nissan hardbody
Runnin' Lean?
I had similar issues when my vacuum line to the petcock was iffy. I saw that your petcock was drilled but could fuel flow still be insufficient to meet demand at WOT?
The filter above the petcock can get gummy enough to slow fuel delivery. The hole in the petcock could be creating some sort of flapper valve (long shot) The fuel line clogged or kinked. The last and perhaps most likely place is a sticky float needle.
The plug color suggests lean, so I'd look for a fuel flow obstruction somewhere. Hopefully you're not running so hot that the loss of power indicates and imminent seize.
CharlotteSpreeRider
Post by CharlotteSpreeRider »
I don't think your carb is clean enough. Pull the main jet and emulsion tube, clean them out real good, and clean the well the the emulsion tube and main jet reside in. Make sure you have sufficient fuel delivery, as mentioned above. Petcock, filter, etc. I had a similar problem before, and it was resolved by cleaning out the gunk that was residing at the top of the emulsion tube, where the needle seats.
It's not the adjustment screws, they don't affect WOT operation.
Good luck!
-aseigler
kho20
me too
Post by kho20 »
im cleaning it as we speak and im gonna clean my pet * again jus for * and grins cus every once and a while it doesnt happen and its like it hits a powerband at 25 so im sure the screws are in the right setting
okay new problem lol took the carb and cleaned it all up put it on and wouldn't start got to lookin at it and fuel was coming out of the overflow port,, i lossened the drain screw it started right up and rode it sucker hit right before the 35 mark so now i got rid of it starving for fuel now its too much.
so is the float pin sticking open or did i get something wrong when i went back or what ??
82 v45 magna
97 dodge 12v dually
87 nissan hardbody
WOT problem: My guess is that it's struggling to 30 MPH, and then dying off to lower speed, like 15-20? That's signs of overheating due to a restricted/gummed up main jet, which it sounds like you fixed.
By the way, don't rev it on the stand like that, you can easily overheat / overrev the engine.
Overflow: Check your float valve for damage. If it looks good, use the toothpaste + Q-tip in drill to resurface the inside of the float fuel shutoff at carb.
Floating
The float valve resurfacing Noisy suggested is a good idea. Don't overdo it with the Q-Tip.
In my case, despite looking completely normal, I couldn't get my old float needle to work at all. Only a new one corrected the problem. Honda-san can get.
circusracer
Post by circusracer »
Did you install an aftermarket filter?
84,85,86 sprees: Intake mod, drilled pipe, .020" milled 1985 head, dome piston, 2mm raised exhaust port, sb50 reeds, 34mph average.
kho20
Post by kho20 »
k well im gonna try cleaning again and resurface the float needle seat tomorrow... the filter is stock except for the lid its some where in the shop (jus no clue where lol) but i made one for now thats pretty close to the stock one so i dont think thats a problem so ill keep yall updated on the progress
82 v45 magna
97 dodge 12v dually
87 nissan hardbody
