Flat roller weights
Aero Fifty
Flat roller weights
Post by Aero Fifty »
I checked my rolller weights for the first time yesterday and they are flat as *. Some are almost worn to the center metal part. So it looks like I'll be needing a new set asap. Any idea of the stock roller weight for an aero?
Also anyone ever try Dr. Pulley sliding roller weights? I found them while searching for replacement weights online. Supposed to last longer and perform better than regular round rollers.
http://www.unionmaterial.com/rollerweight.htm
http://www.monsterscooterparts.com/16x1 ... ights.html
Post by Kenny_McCormic »
Rollers already made into sliders sounds like a great idea to me. That way wear doesn't effect performance as much.
burnt_toast
Post by burnt_toast »
the sliders are OKAY, rollers are king for best shifting
measure your stockers, then get some that are 0.5-1g lighter, install
enjoy the performance
projects galore :nerd:
HondaCharlie
Post by HondaCharlie »
how is he going to measure or weigh his stock ones if they're flat? The weight wouldn't be the same as a new one would be
HondaCharlie
scooterwerx
Post by scooterwerx »
ehh, the weight of the plastic is negligible compared to the weight of the steel inner bit...thanks too for that 18mm dio belt, hondacharlie....
Aero Fifty
Well I don't have currently have a scale than can measure grams but I did find a list of stock roller weights: http://www.beedspeed.com/html-pages/var ... -chart.htm
Now what is the aero 50 called in europe? The vision, vision met-in, or lead 50?
Sliders
I've seen Dr. Pulleys for GY6 and bigger. I have yet to find any for 13x16 SE05/SA16 varios. Anyone prove different?
Aero Fifty
Looks like SIP scooter has them the cheapest?
http://www.sip-scootershop.com/Products ... ulley.aspx
