ANBODY TRY THESE DR.PULLEY FLAT SLIDING WEIGHTS
INSTEAD OF THE STANDARD ROUND ROLLERS.I WAS
THINKING ABOUT GETTING THESE BUT THERE OUT OF
THE 8 GRAM WHICH I WANTED.I THINK THESE ARE 5 GRAM.
[/url]http://cgi.ebay.com/ebaymotors/Dr-Pulle ... ccessories
ANBODY TRY THE DR.PULLEY SLIDER WEIGHTS?
needfasterthan31
01 Elite SR50
>Polini Contesta 72cc Kit (To be soon installed)
>R1 Pipe (To be soon installed)
>Keli Variator
>9:1 gears
>Keli Variator
>9:1 gears
i use them in my ruckus. they dont give you any huge gains performance wise, but being that they are not round , they arent as likely to get flat spots
BARC
Project Aero:
/Polini 65cc BB/high output coil/KN Variator/10g weights/extra wiring removed/plastics chopped/230mm rear shock and relocated shock mount/Semi-rigid front / 90/90/10 motard tires/Ported\polished/dio alum.rear wheel/No crank fan/Pre-mix/
Project Aero:
needfasterthan31
i seen a commercial for them on youtube.com and they said being that they are flat when you are at top speed they go up higher than the normal round rollers which creates a higher gear and more top speed.thats just what they say.thanks for the reply and im hoping to get a few more replies from people using them because i need to order lighter rollers but was holding out until i get some feedback on these dr.pulleys.for the price they better do something
better.
better.
01 Elite SR50
>Keli Variator
>9:1 gears
>Keli Variator
>9:1 gears
ive seen a few issues on friends bikes where the slider "jammed" in the ramp causing the vari to not open back up on deccel.it was a quick fix to un jam the slider and be back on our way but it was kinda annoying, ive never had mine jam , but they were given to me after very light use, it allmost seem that there is a breakin time w/ these roller where they may jam in the first 100 miles or so . but after that they work fine.
BARC
Project Aero:
Project Aero:
Ramp Plate Hangup
Do they hang up on the sharp edge of the ramp plate? If so consider rounding that edge off with a file or a rotary tool.
thing is with the aftermarket pulley im running, rollers my belt seems to be riding as high as i would want it to go on my pulley.needfasterthan31 wrote:i seen a commercial for them on youtube.com and they said being that they are flat when you are at top speed they go up higher than the normal round rollers which creates a higher gear and more top speed.thats just what they say.thanks for the reply and im hoping to get a few more replies from people using them because i need to order lighter rollers but was holding out until i get some feedback on these dr.pulleys.for the price they better do something
better.
Re: ANBODY TRY THE DR.PULLEY SLIDER WEIGHTS?
Update:
yes they WILL develop "Flatter" spots
BARC
Project Aero:
Project Aero:
needfasterthan31
SPREE: When CHEVYGUYJAY did my 9:1 gears and some other things we looked at my pulley system and my drive belt was also riding as high as it could. It seems like the Dr. pulley weights would work best with the Dr. pulley variator/ramp plate. I have yet to try them.
01 Elite SR50
>Keli Variator
>9:1 gears
>Keli Variator
>9:1 gears
