SA50P (Restricted guys) Oil pump Q
burnt_toast
Post by burnt_toast »
Workin on my '98 SA50P today I realized I did not have the split throttle cable going to the oil pump like on my SR50's
I went ahead and rigged it wide open, but wanted to confirm that was the best thing to do, thoughts?
Mods at the moment are exhaust and variator, more coming soon
projects galore :nerd:
bradthreee
Post by bradthreee »
Im curious with his too, In for a answer...
veedubh20
Post by veedubh20 »
sa50p sold restrict motor, that has smaller main jet, exhaust washer plate om muffler and a ramp thick plate restriction, back of high speed pulley, no oil cable
Sa50 , had bigger main jet, no washer on muffler, and oil pump cable.
Doesnt have a thick ramp plate, that cut down speed.
Factory Setu-P
BT has no pump cable:
How was it set up from the Factory?
burnt_toast
Re: Factory Setu-P
Wheelman-111 wrote:Greetings:
yup no cable, therefore oil pump is on lowest possible setting at all times.
I went ahead and tied it fully open since I recall Dac and others doing the same.
I was just curious about the main jet this morning, exactly what I needed to know as far as that goes thanks veedub!
burnt_toast
yup veedub was correct. decided to check out the jet before heading to work today, luckily had a spare SR50 carb laying around.
SA50P main jet = 68
SA/SR50 main jet = 78
now howbout them oil pumpz :?:
losthope
Post by losthope »
burnt_toast wrote:yup veedub was correct. decided to check out the jet before heading to work today, luckily had a spare SR50 carb laying around.
SA50P main jet = 68
just wire it open or eliminate it and pre mix.
burnt_toast
done and done, oil pump tied to WO
I premix on my miniCorsa'd elite, trying to avoid it on this one ;)
would like a nice steady cruiser for a change :D
veedubh20
Post by veedubh20 »
I rode, with oil pump cable that has sa50p block, s muffler was grind off washer, ran stock pulley/ramp , just throw away a thick ramplate/ 3 screws, and round cover plate. very good speed! :D gn2 oil
bradthreee
Do you want a 2 wire cable? I have one that I couldnt use for my application so if you want it $5 shipped
bakaracer
Post by bakaracer »
if you took out the welded washer out in the exhaust,the 78 main is to small still.you have to bump it to a 85 or 88 jet.yes tie open the injector.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
burnt_toast
bakaracer wrote:if you took out the welded washer out in the exhaust,the 78 main is to small still.you have to bump it to a 85 or 88 jet.yes tie open the injector.
85 or 88 main at 50cc?? :shock: Can anyone else confirm this? sounds like main size you would run with 70cc..
my only current mods are YMS exhaust and OKO pulley with 7.5g net
78main seems fine, my jog had 76main, stock bore, stock carb & box and with a tec RS pipe worked good.
maybe you have to bump yours up because of elevation? I'm very close to sea level here
and brad thanks for the offer but I have a spare split cable, but will be going to fully adjustable for a carb upgrade in the future anyway so wiring pump open seems good to me :)
scooterwerx
Post by scooterwerx »
im running a 90 in my elite e with nb50 engine, it has the leo vince sp3 and a uni filter, it still looks a little lean too! the added rpms really get the fuel going, i guess. i found it necessary to increase the jet to an 85 just from the filter, and the pipe just made it scream, more rpms and i could tell it pulled way harder off the bottom. i dont know if derestricting a stock pipe would yield the same results, but an 85 sounds like a good starting point, im at 1300ft of elevation btw.....
burnt_toast
right, but that is with open filter.. and yes 90 actually sounds pretty lean with that combo, 95-100 might be better
i'm at just pipe, vari and stock carb stock airbox with cut unifilter foam and don't plan on running open filter unless I go 70cc.
veedubh20
Post by veedubh20 »
today, I do some riding, burn a gallon gas
:lol: .
my stock moto ran gn2 oil. idle run smooth, then a/f screw set @ 1 1/2 turn out. (sr50 main jet) E10- 92 gas. Exhaust tail pipe burns very clean! :D outside temp 80-90
