good idea, bad idea?
fireblade
Post by fireblade »
would it be a smart move to machine material from the bottom of the jug where it bolts up to the crankcase, to raise the deck height of the piston and increase compression? Or is there some pitfall in doing this?
HONDA NQ50 "FIREBLADE"
bakaracer
Post by bakaracer »
its easier to deck the top.but what reason are you decking it for?
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
The reason guys used to do this on some bikes was to alter all the port timings. Frankly, unless you understand and are comfortable changing port timing, I wouldn't do that. Just knock the material off the head instead.
fireblade
Post by fireblade »
what about removing material from the top of the jug?
Well, the head is easier to machine and cheaper to replace. I guess I don't see why you'd mess with the jug at all.
burnt_toast
Post by burnt_toast »
indeed, head is aluminum jug is cast
projects galore :nerd:
keithw
Post by keithw »
The port timing on these is very conservitive. Machining the bottom of the cylinder will lower the ports reducing performance. Some actually spacer up the cylinder to raise the ports. The easy answer is mill the head. If you want to get fancy spacer up the cylinder then cut down the top of the cylinder the amount of the spacer. Make sure you understand what the ports are doing and the port angles before and after.
keithw
Honda Spree, 1985.
Another Honda Pal
