Stereo install questions on 99 elite 50cc
I have browsed the forums and looked at many youtube vids etc trying to find the best way to put a nice stereo in my elite and keep it affordable. From what I have I found, it looks like the best thing to do is to buy like a 300w amp and install under the seat and wire speakers to where my glove box is now. I then would run an rca out to my mp3 player.
Anybody else provide any info on this. Im not that handy with wiring etc. so the easier the install the better. If you have info I would appreciate it. Feel free to post links to speakers, amps etc.
Thanks a ton.
Birdman
Thanks a ton.
Birdman
I did this in a car the had no stereo once. The amp is easy to wire up as there are only 3 wires (positive, ground, and one you connect to a circuit that is only on when the vehicle is switched on).
As for putting one on an elite, I imagine you're going to want as low of amperage as you can get because these scooters don't put out much juice. Otherwise you would just have to make sure that you charged your battery regularly.
1986 Spree w/ '87 SE50 motor
A 300 watt amp is FAR too much, unless you want to carry a big * battery to run it all(because like I said,these bikes barely have enough power to keep the lights on and battery topped off) you are screwed. A boombox is a far better option.
As much as I hate giving out my own future plans, here it goes.
Get this amp:
http://cgi.ebay.com/ebaymotors/NEW-300- ... ioQ5fVideo
I planned to remove my oil tank (run premix) on my Spree and put this amp in its place (it'll fit). Run a + wire and a - wire right to the battery, prolly 12ga wire at the least. Also run a SWITCHED 12v wire to the amp turn on.
Connect your speakers as you normally would and connect your MP3 player through the RCA inputs on the amp.
I planned on running these 4" marine speakers, as they are waterproof.
http://cgi.ebay.com/2-NEW-100w-4-INCH-P ... =72%3A1205
Enjoy
Get this amp:
Enjoy
2006 Sachs Madass
- FTP 140cc Kit
2006 Xkeleton Trickster
- Lifan 90cc auto
- FTP 140cc Kit
- Lifan 90cc auto
Could I install this 10 inch sub
http://cgi.ebay.com/NEW-LEGACY-4-OHM-60 ... dZViewItem
along with these 4 inch marine speakers
and would the 300w amp power these and would I not have to worry about draining the battery etc. Thanks for the input
No, the sub would not work.
1. There are not enough channels on that amp to properly set up the sub/speaker combo.
2. There isn't enough room to make a large enough sealed off area for the sub to work correctly.
3. Just no, lol.
The speakers should sound good. It is 300 peak watts x 2 channels @ 2ohm.
Those speakers are 4ohm's a piece so they will be running 75w peak x 2 channels.
Thus, you will only be experiencing 37.5w x 2 @ 4ohm. This is very similar to a standard aftermarket head units output.
I do not know the output amperage of the stator on mopeds, so your guess is as good as mine in this case. My guess would be that it would be alright.
3. Just no, lol.
2006 Sachs Madass
- FTP 140cc Kit
- Lifan 90cc auto
- FTP 140cc Kit
- Lifan 90cc auto
Booming Bass is Best
Guess again. The charging system might have enough juice to spare to run your iPod and earbud headphones, which is a far better option on an open vehicle anyway.
buts its also highly illegal. I use earphones now but would like a stereo.
something like this
http://www.youtube.com/watch?v=VGpz38nnQMc
something like this
So I bought this amp. I have seen others with it and they seem to like it.
My only other question is what about these for speakers?
http://www.crutchfield.com/p_022AW190WH ... tml?tp=188
They should fit. I just want to make sure the power drainage wont be too much on the battery. it seems some ppl on here say it will drain the battery and others say it wont be a problem. I just want to be 100% sure before I pull the trigger.
Thanks
Thanks
