[Spree] No rubber between the carb and the float
3 Steps Back
so i went and installed the cardboard piece, and i think the gas leaking problem is even worse now
i think i'll go ahead and remove it, but i don't know where to go from there
You could go back up 3 posts and re-read the second line... :)
3 Steps Back
You should re-read the 10th post in this thread. Second line... :)
Lamb
Post by Lamb »
right, but i don't even know if that's the problem now that i've found the rubber in the lining of the carb
is there a piece that presses between the float and carb, or just the one that fits in to the carb directly?
im probably describing this horribly, i'll get pictures to demonstrate what i mean tomorrow
this cardboard shenanigans is coming to an end either way
GlynnC
Leaking carb
Post by GlynnC »
Leaking needle valve? Clean seat (s,ee many posts on this subject) possibly replace valve. If you thought the price of a gasket was bad, these dudes are $15.
87 Honda Spree
86 Honda Spree
darat
Post by darat »
just go get a gasket kit. best bet or use black rtv
Lamb
Post by Lamb »
alright, so when i went to disassemble the carb, this cabley thing just fell apart
here's the carb with homemade gasket installed
this is what i'm dealing with, im thinking the black part in the carb is the gasket that i thought i was missing, so i'm not sure if there should be another piece between the two of them
this little * is what i first noticed gas dripping from
got any ideas? :/
toboggan
Post by toboggan »
Hello,
Are you talking about the red "cabley" thingy, or the black "cabley" thingy you're holding in your hand?
Well, the red "cabley" thingy is the vacuum line that pumps gas into your carb.
The black "cabley" thingy you're holding in your hand is the electric choke.
If its dripping from that hole, that means you're getting too much fuel in the bowl (correct me if i'm wrong) Which means you should check your float needle seat.
If i were you, i'd go and thorough clean the carb 5 times![/i]
87SpreeInGA
Post by 87SpreeInGA »
All I know is that a finger cot will not work. It is too small. But there are larger sizes.
toboggan
Post by toboggan »
toboggan wrote:Hello,
Lamb
Post by Lamb »
i mean the black cable i'm holding-look in the carb, you can see the spring and needle that would otherwise be inside of the cable
toboggan
Post by toboggan »
have you tried to put it back together, to see if something snapped off, i've never had to deal with a broken choke
ALOW1
Post by ALOW1 »
Lamb wrote:i mean the black cable i'm holding-look in the carb, you can see the spring and needle that would otherwise be inside of the cable
The black thing you removed is called the bystarter.
It looks like you may need a new one. I have never had one come apart like that, somebody else should chime in and give better info.
Lamb
Post by Lamb »
i sloppily plunked it together and it ran before, but could it have anything to do with the carb leaking?
darat who's been posting to this thread made a nice set of pics and text for bystarter assembly, been handy for years. Thanks darat, your post has saved many a broken bystarter.
http://www.hondaspree.net/phpBB2/viewtopic.php?t=1504
darat
Post by darat »
no problem man i have been on here for years now.. lol to many but i love these lil things glad to help
