Carb Help!! PICTURES INSIDE!
vette76
Post by vette76 »
still a carb proble. thats not what i was talking about. there are 3 pieces to the float. the float, the float pin, and the float needle. that small needle is a valve. make sure you have it. the float holds it and it is located on a little hole next to the pin. make sure it is fitting into the float guide nicely and operates back and fourth with the float. oil wont do anything on this. to be honest i would clean it off because it might do more harm then good.
87' spree (SOLD
12' wrx
Justinsane
Post by Justinsane »
so judging by the picture? do i have all the float parts?
MySpree
Post by MySpree »
you cant tell the float valve goes under the float it self and it connected to the inder side of the float by a groove.
Justinsane
does anyone have a picture of what it all should look like/consist of?
MySpree
Post by MySpree »
yes i will post one later tonight.
Justinsane
well, i think im in trouble here,... becuase ive taken the carb apart 3 times today, and theres nothin in there except for the float, and pin.... there no needle jigglin around...
MySpree
Post by MySpree »
hey i can help u out dont worry. if u need it i can send u a carb to use while urs is here and ill fix ur carb for ya. all clean it put some new gaskets and yea for free.
Justinsane
i think we'll have to do that... but i wanna make sure that mine is 100% needing to be worked on... because i dont wanna put you through the trouble
K_OS
Post by K_OS »
Before you do anything tighten the screw that I marked in the photo. This is a drain needle.
________________________________________________________________
Be Cool
K_OS
vette76
Post by vette76 »
thats not going to help. the gas isnt coming out of the drain nipple.
87' spree (SOLD
12' wrx
K_OS
Post by K_OS »
Oops my fault... that is what I get for not letting all the pictures load.
Be Cool
K_OS
eager_beaver
Post by eager_beaver »
make sure your bowl aint sticking, go buy carb cleaner mine did the same i cleaned it with carb cleaner and it works great
Justinsane
ive tried everything,... im taking the carb apart again... 5th time.. tonight and taking pictures, because im convinced that im missing a float part.
hondaman
Post by hondaman »
Your gonna need that float needle for the carb to run right. Also make sure your carb gasket is in good shape.
Justinsane
ok, let me repeat.. i have no idea what a carb should look like, so i dont know if there are any parts missing, or where the specific parts are.
but these picture are of the float assembly... thats all that was in there... no other parts
that picture shows the floater, and the floater pin.. but no float needle... where is it/should it be??
this is a picture with the floater and float pin removed... is the float needle supposed to be somewhere under that???
WELL ITS NOT! :lol:
Image[/list]
