elite 10:1 aftermarket gears who sells them?
needfasterthan31
Hey guys, i talked to vt cycles yesterday and they told me with my stock motor and keli variator that i would be best off with and get the best performance with 10:1 gears and that 9:1 gears would not be good and i would get the same top end on my stock motor with 10:1 gears opposed to 9:1 but they said they no longer carry 10:1 gears, any leads on 10:1 gears? and do you really think 9:1 is too much. i hear people on here using them with stock motors if i rememebr correctly, but someone also told me not to get them until i get a big bore which im not sure that i want at this time. i am ready to order new clutch springs from vt but was hoping to order gears at the same time, i really do not care as much about takeoff speed unless it is going to be real slow, but do not want to be dogging up hills because my gears are so tall. any advice or recommendations.
01 Elite SR50
>Polini Contesta 72cc Kit (To be soon installed)
>R1 Pipe (To be soon installed)
>Keli Variator
>9:1 gears
>Keli Variator
>9:1 gears
If your planning to upgrade to big bore later get the 9to1 but if your just staying with the stock bore get the 10to1.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
91 yamaha tzr 250r
- burnt_toast
pacific -3hr mountian -4 midwest -5 east coast -6 :lol:http://nist.time.gov/timezone.cgi?Hawai ... s/-10/java
I Dream My Owns
MadDog, you know we love you like a brother, but
There you go again!
_________________
Now Accepting Your Tax-Deductible WHAC Donations
PS: I'm still waiting for you to send me my Dio 16...
There you go again!
If you're not willing to share your ultra-secret, special tricks of the trade, why exactly are you posting? Please, do tell.79,000 mi. and so dependable, if you use common sense and a few tricks of the trade
_________________
Re: I Dream My Owns
From what I've read, mostly using high-quality components from Japanese and European suppliers and making sure your jetting is right for your setup. Most guys I see with blowups here are cutting corners with cheap parts and/or they do a "bolt and go" without making sure things will work together.Wheelman-111 wrote: If you're not willing to share your ultra-secret, special tricks of the trade, why exactly are you posting? Please, do tell.
needfasterthan31
Thanks for the replies fellows, one person says 9:1 will work just fine, then someone else said do not go with 9:1 and go with 10:1 , it seems the 9:1 gears are readily available,i seen Daywot has 9.8 gears which are closest to 10:1 but says you only get like 2-3 mph increase which does not seem much. anyone else running a high speed variator with a stock motor and 9:1 gears? if so how is your speed throughout the range? just hoping to get a few more opinions before i order something i may regret getting because i think i will keep the stock bore for a while and do now want the bike dragging * all the way until it hits top speed and dogging up inclines.
01 Elite SR50
>Keli Variator
>9:1 gears
>Keli Variator
>9:1 gears
- burnt_toast
needfasterthan31
Thanks guys, ill order the 9:1's then. i was going to order them through vtcycles because i talked to him and was going to get all the clutch springs as well, figured i would save the shipping and get it all at once, i know ill have to mess with the rollers but glad i got a few last suggestions, and thanks Kenny M.C. you were right off the start- i just wanted to get a few more replies.
01 Elite SR50
>Keli Variator
>9:1 gears
>Keli Variator
>9:1 gears
9.1 Is great for a stock bike.
Highly recomended..plus they are there if you ever upgrade the motor.
I have them on my bike ('98 elite) with a keli vari.
Acceleration is still good..(my friends are surprised how zippy it is for a moped)
Stock weights and I run 45 mph no problem..With a tailwind I've almost buried the speedo needle on a few different occasions.(I weigh 170ish pounds.)
The only complaint I have is a slight bog in the 0-5 but after that its a-okay.
Dac had them to..he ran 45-50mph
Get the 9.1..you won't be disappointed
Honda Elite SA50-S
Stock motor, 9:1 gears, Kelli High speed pulley=a top speed of ?? Maxed the speedo out if that counts..average 45 mph
average 85 mpg
average 85 mpg
