Spree won't start
theosmithers
Spree won't start
Post by theosmithers »
Greetings all! I am having a heck of a time and I hope that someone can help, because I'm ready to pull my hair out with this one. I buy pieces and parts of sprees and make them whole and running just as a hobby, but this one has me stumped. My latest project has a spree with spark, with a good carb, and with gas that will not start. The exhaust port is clean, the carb is off a running spree, and all of my electronic parts have been switched with a running spree. The only thing that I can think of is that I have put this motor together from many different motors, and I replaced parts from different year motors. Does anyone know for sure if there are any parts that are NOT interchangable, or have any ideas of anything to check? ( I also have 125 pounds of compression because I put in a new top end)
toboggan
Re: Spree won't start
Post by toboggan »
Welcome,
You say that you have a good carb, but since you've switched it, have you cleaned it? there might be that little chance that when you switched a piece of dirt got in there or something and is clogging one of the jets!
ida34
Post by ida34 »
Did you check the reed valves also? My spree showed 110 compression but would not start. I checked and found air filter fragments in the reed valves. Pulled the fragments out and no problems now.
specmiata99
Post by specmiata99 »
I have the same problem with my 85' i am working on. I ahvent checked the reeds but assmed with only 120 miles theyd be good. Should i check them? Mines sometimes has mist coming out the intake after starting attempts, whats up with this and does yours do it also
theosmithers
Yes, I cleaned the carb before installing. But, no, I havent' checked the reed valve yet. Was yours stuck open? I will check it then start again.
