Hey there I just got an 86 spree from Indiana and I live in calgary. I need some help changing the air intake to my altitude level... Any suggestions
Corry R
USA to Canada altitude level change
Re: USA to Canada altitude level change
Above 4000 feet? If so you can consider simply removing the stock airbox and substituting a pod or K&N filter. Doing so will let more of that thin air into the carb and may nearly match the stock jetting at sea level. With the stock box, I suspect you would need to swap for a main jet that's a size or 2 smaller, which may be hard to find.
You will need to do some jetting.
Calgary is around 3400 ft. Indiana is 800 ft roughly. It might run a little rich in Calgary but it shouldn't be too bad. It's not like Honda normally changes the jetting for different areas. If your Spree is running rough it's probably something else.
Sweet site with info on Honda's and tons of other scooters: http://www.MotorScooterGuide.net
Thats awsome, thank you guys this will help a lot.
- scooterwerx
we took our scooters to colorado, my aero barely ran at 5000 ft, im at 2000 ft or so here, honda has a high altitude jet for most models...
