DEAD SPREE NEED HELP
DONDIRTBIKER
Post by DONDIRTBIKER »
I bought a nice 1985 spree and hooked it up to a battery charger to jump start it.. nothing when i turn the key on, no dash lights nothing, checked the fuse to the battery and it looks good, (anyone know what amp this fuse is supposed to be?) could it be the starter relay or is there another fuse.. it looks like a good bike and its all there..
thanks for your help people..
thanks
Re: DEAD SPREE NEED HELP
Post by Kenny_McCormic »
Bad wire is my guess, start tracing.
jguy
Post by jguy »
There are folks on this forum that know Waaaaaay more than me, but would it hurt to bypass the ignition key? If you don't have a volt ohm meter handy, I mean. And, I just found recently (see my post on "Funky Turn Signals"), that it pays to check the wiring up front to make sure all the colored wires are plugged in to the same color.
Just my 2 cents worth. BTW, welcome to the forum.
'86 Spree
'80 Motobecane 50V
Just Ride
coolbeans
Post by coolbeans »
I'm not sure if this is the same with a spree, but I had a problem starting my Aero when I first put it together because you have to have three things for it to start:
1. Ignition Key on
2. Brake Lever Pulled
3. Run switch on
1985 Honda Aero 50 5k
turtle13
Post by turtle13 »
coolbeans wrote:I'm not sure if this is the same with a spree, but I had a problem starting my Aero when I first put it together because you have to have three things for it to start:
1. Ignition Key on
3. Run switch on
not gonna lie, when i got my spree running i sat there for 5 minutes cranking, then realized "oh you gotta put it in run, duh!"
switched it over to run, fired right up... looked around to see if there was any one laughing, and putted away. :oops:
'62 125cc Honda cub
DONDIRTBIKER
Well i got here running, the small wire to the battery fuse was thin and almost ready to break... cleaned the carb, checked the air filter, inspected the clutch and belt..
everything looks good but she runs like its rich and has no power, seems real slow,, any ideas,, decarbonize ?
thanks for everyones help..
Check bystarter.
bradthreee
Post by bradthreee »
Kenny_McCormic wrote:Check bystarter.
I think he meant to say "clean the carb" :mrgreen:
