How to brighten your old faded, chalky plastics
Post by Kenny_McCormic »
Just discovered something I though i would pass along.
Found out today that a WD-40 soaked rag followed by a dry one a few minutes later works wonders on body panels, turn signal housings and pretty much anything plastic on the bike, shines up the seat too. My spree went from a 20 yard bike to a 20 foot bike.
GlynnC
Re: How to brighten your old faded, chalky plastics
Post by GlynnC »
Thanks Kenny for the tip--thats what I like about this forum, folks helping each other, and sharing info!
Will try this tomorrow!
87 Honda Spree
86 Honda Spree
scooterwerx
Post by scooterwerx »
haha watch out for dust though, WD40 is like a magnet! turns it brown...
adark248
Post by adark248 »
oooooooh yay gotta give this a try :D
1984 Honda Aero 50
1986 Honda Spree
bradthreee
Post by bradthreee »
I used Engine Brite engine degreaser on mine with a sponge, followed with a steady stream of water to remove the degreaser. Then sprayed Son of a Gun protectant in the yellow bottle as it was still wet. Let it soak for about 5 min not letting it dry then wipe off with a clean cloth. This did wonders for the plastics on my Gyro. :mrgreen:
burnt_toast
Post by burnt_toast »
Only thing I would think is this trick is likely temporary, similar to polishing. eventually would fade back
But a good one, especially if you have plenty wd40 handy
projects galore :nerd:
GIJoeBob
Post by GIJoeBob »
I wet sanded my plastics to remove the surface oxidation. That way I don't have to redo it after the WD40 wears off.
The thing is dust doesn't stick to it any worse than it used to and it doesn't fell greasy. i would think that engine degreaser would dissolve plastic.
TURN1
Post by TURN1 »
Woot!
Pass on the ALOHA Spirit!!!
bradthreee
Kenny_McCormic wrote: i would think that engine degreaser would dissolve plastic.
Others may, but the "Engine Brite" made by Gunk is made for all under engine plastics as well. Its the best stuff I have ever used. I wouldnt tell people to use it if it would dissolve the plastics :roll:
Another thing I discovered, boil a carb in water to remove varnish. Do it outside in a junk pan(or go ghetto and use a dented to * dog food bowl)on a burner nobody cares about. Its not as good as buying a bucket of dip but it works.
Lunytune
Post by Lunytune »
What about Armorall? I think I can find a bottle in my son's stuff that he left for Pop to inherit when he left home. It's mine now.
GIJoeBob
Post by GIJoeBob »
Lunytune wrote:What about Armorall? I think I can find a bottle in my son's stuff that he left for Pop to inherit when he left home. It's mine now.
I have read in more than one source that Armor All is bad for plastic. It eventually damages the plastic.
I stick to my above mentioned process. It removes the chalkiness instead of hiding it.
dreamer1uk
Post by dreamer1uk »
Hey,
Mothers has a nice product called Back To Black that i have used on my Black Spree and on my Mustang's trim with great results too.
I lied The Colgate tooth paste works OK , But after seeing some other postd on cleaning ,I tried Mothers back to black ... What a difference
Day & night worked great and a lot less work .So use the colgate for brushing your teeth and Mothers Back To Black for cleaning your plastic .
Rub Rub Rub  in one direction do not go in circles .
