Aero speedo woes
code47mastermind
Aero speedo woes
Post by code47mastermind »
I recently bought an 86 Aero 50 which did not come with a speedometer cable.
I just got one in the mail off of ebay and when I hooked it up it makes a LOUD noise from the speedo while moving
at first, It sounded like the cable was spinning inside of the speedo housing and creating the sound but that is not the case
while accelerating, after maybe 5-10 mph, the speedo shoots up past 35, as far as it will go... looking like I just accelerated like a bullet
capturedbyrobots
Re: Aero speedo woes
Post by capturedbyrobots »
Did you grease the heck out of the cable?
Sounds like it was binding up, then releasing causing the spike.
GIJoeBob
Post by GIJoeBob »
Yeah, lube the crap out of it.
Does the fitting on the speedo itself rotate freely?
code47mastermind
yep, that was my problem
it's now packed with grease and works flawlessly
thanks guys
adark248
Post by adark248 »
mine totally pooped out the other day. just stopped working on a ride :(
1984 Honda Aero 50
1986 Honda Spree
