air filter
grafittijunkie
air filter
Post by grafittijunkie »
so i put an air filter on instead of running it open carb, and i was wondering if i have to oil the filter first. idk i'm running it as is right now. its the uni dual stage filter. the one with the red outside and the black inside. let me know if i need to oil the filter, and if so what kind of oil i should use.
bakaracer
Re: air filter
Post by bakaracer »
get the k&n oil spray and spray a light coat on the filter.its to trap the real small dust.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
Re: air filter
Post by Kenny_McCormic »
Honda recommends 80-90w gear lube for their foam filters IIRC, uni recommends their own oil, I use 30 weight non detergent lawnmower oil on everything.
grafittijunkie
Re: air filter
so you can put motor oil on it?
toboggan
Re: air filter
Post by toboggan »
Yes but it has to be that weight
Lunytune
Re: air filter
Post by Lunytune »
I don't know how essential the type oil is to a scooter, but on my mowers, I saturate with whatever motor oil is handy, usually 10W40 and then squeeze it out. Whole idea is to compromise between sponge filter and the old oil bath. Anybody remember them?
Re: air filter
Any motor oil will do, the thicker the better. I have even used 2 stroke oil. Just get it soaked and squeeze it out, then squeeze it in a rag to get more out.
