Cleaning solution...
Just wondering what is best to use to clean up grease/grim build up on engine?
Re: Cleaning solution...
for a general cleaner, I prefer Blue Coral All Purpose Cleaner & Degreaser. It cleans most anything in the engine area but is not as harsh as gas or carb spray. So it only cleans, it does not eat or discolor anything. As a bonus, it is 100% USA.
http://www.bluecoral.com/EXTERproducts.asp?page=1_5
- JohnRobHolmes
- Goped
I like simple green for my cleaning. Does a good job of cutting dirt and grease without being lye based. Safe to get on hands and plastics.
- burnt_toast
any auto grade degreaser like simple green for auto application works well for light grease.
for heavier and deeper grease brake cleaner does WONDERS
this was mostly done with several passes of brake cleaner, one or two auto degreaser, toothbrush and green scrubbing pad (note walmart brake cleaner in background)
projects galore
- wikked_spree57
I use Westley's Bleche Wite.
It works pretty good, and the heavier you spray it on and the longer it sits, the better it works. Works even better with the use of a powerwasher.
1994 BMW 525i 5 speed BEAMER TIME
1983 Yamaha XC 180 - Bought barn fresh in mint condition and 254 miles. Best bike I ever owned
I'm with toast on this one, brake cleaner works wonders. although i have a parts cleaning tank o' mineral spirits w/steel brushes for extreme cases, and have also had great luck with acetone as a somewhat cheaper bulk alternative to brake cleaner
acetone also gets everything off your dirty@$$ hands, though i'm sure it's not "good for you"...
Random question for californians, how do you do ANYTHING??? every product i listed kills californians, the fragile creatures they are (or so the label tells me.) good thing i'm of hardy michigan stock. even my steel brush came with a warning that said it could kill a californian...
Ol' Red
Broken...
Spreeio
1987 Spree
With af16e powah!!!!
Broken...
Spreeio
1987 Spree
and brake cleaner is?Spreetard wrote: acetone also gets everything off your dirty@$$ hands, though i'm sure it's not "good for you"...
Has anyone had a problem with the brake cleaner getting on none metal items and causing problems?
- wikked_spree57
Brake cleaner eats plastic and paint. I got it on my old Razz rear cover accidentally, came out the next morning to a huge white spot on it
- bradthreee
I dont know what you are talking about.Spreetard wrote:Random question for californians, how do you do ANYTHING??? every product i listed kills californians, the fragile creatures they are (or so the label tells me.) good thing i'm of hardy michigan stock. even my steel brush came with a warning that said it could kill a californian...
I would imagine people from michigan would be more brittle due to the intense cold and poor food supply.
We're stong in cali, the weather is always nice and warm and we eat everything organic.
Dont b hating
You have to forgive Spreetard . Here, spring just arrived two weeks ago(at least here in "warm" southeast Michigan).Up north in Manistee(well over there) they get allot of snow from the lake effect.Spreetard probably just got dug out from under 4-5' of snow.Most likely suffering from a terrible case of cabin fever(you know, when you can't ride for months on end).So be a little understanding,at least till his eyes get accustomed to sun light.Your two wheel brother.Carp
'98 sa50(thanks evailone),'95 sa 50,'86 spree(thanks wikked_spree57) ,'82 nu,'81 puch,'80 nc,(2)'78nc
'78 ranchero,'77 pinto wagon,'64 t bird,'48 ford tudor,'31 ford furdor
and they all need lots of love !!!
apephoto222
- BMX
use carb cleaner after getting most of the junk off first with a rag.. Spray carb cleaner on the object and then use a rag with a shot of carb cleaner on it
bradthreee wrote:I dont know what you are talking about.Spreetard wrote:Random question for californians, how do you do ANYTHING??? every product i listed kills californians, the fragile creatures they are (or so the label tells me.) good thing i'm of hardy michigan stock. even my steel brush came with a warning that said it could kill a californian...
I would imagine people from michigan would be more brittle due to the intense cold and poor food supply.![]()
Dont b hating
BTW, bradthreee, how much for a used spree engine shroud?? (shipped to the frozen wasteland, of course
Ol' Red
Broken...
Spreeio
1987 Spree
Broken...
Spreeio
1987 Spree
- burnt_toast
brake cleaner is fine to use on plasts AS LONG as you wipe them down VERY SOON aftereliteguy50 wrote:and brake cleaner is?Spreetard wrote: acetone also gets everything off your dirty@$$ hands, though i'm sure it's not "good for you"...![]()
I literally use it for almost EVERYTHING haha
projects galore
Pull the panels and take it to the car wash. That way you don't have to worry about all those chemicals eating up your paint job, your hands or causing cancer, liver problems, kidney failure, etc, etc, etc.Pake808 wrote:Just wondering what is best to use to clean up grease/grim build up on engine?
