Spree Big Bore Problem
Loppis
Post by Loppis »
I just got my spree running today after installing the 44mm big bore all was good until it hits 20mph then it sputters and stops accelerating. I'm running it with "free flow filter" and the provided jet. Any help would be greatfully appreciated.
toboggan
Re: Spree Big Bore Problem
Post by toboggan »
Break it in first. don't try to take it above 20 for about 400 miles.
Loppis
Post by Loppis »
At half throttle it should be able to surpass twenty it seems like its leaning out on the top end.
bakaracer
Post by bakaracer »
try it with the stock airbox
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
Loppis
Post by Loppis »
we did try it with the stock air box and we got exactly the same results.
jagersauce447
Post by jagersauce447 »
what size jet is it because i have a similar problem with a 100 size jet except mine will barely move.
Loppis
Post by Loppis »
I used the supplied jet which i believe is a 100
bakaracer
Post by bakaracer »
100 jet sounds big.what was your stock jet?
91 yamaha tzr 250r
bradthreee
Post by bradthreee »
Stock jet on a Spree should be 65
bakaracer
Post by bakaracer »
so with the airbox a 72 or 78 jet should be right in the ballpark.100 jet is way big even for a 72cc dio so for a 44mm spree,way to big
91 yamaha tzr 250r
Loppis
Post by Loppis »
what number drill bit do i use to drill out a 68 jet to the size you think will work.
bakaracer
Post by bakaracer »
don't know the number as I don't drill jets.if you have a micro drill set,find the closes drill size to stock and go up from there.drill the next size up from stock and try it first before going bigger on the bit size.
91 yamaha tzr 250r
tazland001
Post by tazland001 »
That is true. you can use a drill bit on your stock main jet. I use to that all the time before I just bought a bunch of jets. I forgot what bit I used to get to a 85. I do have 95s. If I placed a 100 instead of a 95 in you 44mm spree kit, get in touch with me so I can mail you a smaller jet.
Marc
