motor making weird noises
MacgyveR
Post by MacgyveR »
My motor is making weird noises as i go faster. it sounds fine at first than makes a really loud noises that used to not come from the engine when it was warm. Please give me an idea what i should do.
Justinsane
Post by Justinsane »
check the tightness on your spark plug, if its too far down, it will knock, you can tell if its doing this because the spark plug tong will be bent down the the electrode.
otherwise, it may be that you have an exhaust problem.
General Spree
MySpree
Post by MySpree »
is it screaming? mine was makeing this loud shrilling noise, i needed new crank berings! 13 dollers a peace plus seals and crank gasket i was at about 35-40$
MaskedJellybean
Post by MaskedJellybean »
where did you order that stuff MySpree?
maddog
Post by maddog »
crank bearings don't scream they knock and you will loose power, belts sqeal.
Justinsane
you probably got a mouse trapped in your exhaust freakin out and screamin bloody mary....
that never happens...
General Spree
darat
Post by darat »
lol
MySpree
Post by MySpree »
MINE WERE SCREMING MINE WERE RUSTED! HAHA NEVER HAD SEALS WHEN I GOT IN NEVER RELIZED THAT PUT SOME SEALS ON AND CALLED IT GOOD, WELL THAT CAME AND BIT ME IN THE *. WHEN I NEEDED NEW BERIGS AND LUCKLY I HAVE A HONDA DEALER 3 ER 4 MILES AWAY.
