Out of no where i have had a very sudden loss of almost all power in my 1985 NQ50 Spree. It has very little take off and its top end is only about 15 Mph. Before this happened i had it taking off nice and had a top end around 30-35 Mph. So far i have:
1. Cleaned the carb
2. New Spark Plug
3. Adjusted all carb settings based on what the book said
I still have to clean out the exhaust but other than all of that can anyone help me think of other things i could do to fix this problem i am having?
Also do you recommend me getting the Big Bore Kit? Is it work it?
Thanks, Kevin
Proformance Loss Question 1985 NQ50 Spree
Kevindolin2
Re: Proformance Loss Question 1985 NQ50 Spree
Sudden loss isn't consistent with a gradual-onset issue like muffler carbon. Just because it's cheap and easy (somewhat like myself...
), I'd do a compression test before anything else.
http://www.harborfreight.com/cpi/ctaf/D ... mber=92697
Remove spark plug. Screw in tool. Open throttle all the way. Crank until the needle doesn't rise any more. Read.
<80: Hole in piston, broken rings.
80-100: See above, possible reedvalve failure.
Add 5cc GN-2 oil to cylinder via the plug hole & re-test.
Improves > 20PSI = rings
Doesn't change = reeds.
