I cut into the old sealed beam with my light saber(I found some threads on it in google) and JB-d that sucker in. Of course I tried it to see if it will work and low and behold it glows brightly! I used a 9005 HB-1 I believe high beam only. So the low position of the switch is "off" Always make sure you tape off hot wires, don't wanna burn down the house.
Now I know this is probably stupid to do with possible burning/shorting things out, but as long as I don't smell any wires cooking, Im leaving her in there! Its pretty much a jerry rig job, but Im cheap and like to tinker. It looks factory from the outside.
I found a cool mirror at a bike shop and clamped it on. Now all I have to do is get my awesome neighbor to weld me up a nut onto an old kickstart lever and I will pinch-nut the thing onto the shaft we welded onto the end of the broken spindle. I have been just starting it with a 3/4 wrench with the 2 nuts on the piece of threaded shaft.
I think the choke is stuck because when I cover the holes on the airbox it fires on the first, well, wrench turn!
This Express is very susceptible to weather changes but it goes just as fast as my Spree, possibly a bit faster, but you know how each bike is different. It hits 30-31 on a flat run, but has a little less low end that the Spree.
