I am assuming you have an inline filter as well that you're seeing the air bubbles in ? That would not be a concern as long as there is consistent fuel coming through.turbobluemiata wrote:Update: well I got the fuel valve in today, bought a brand new one and replaced the plug at the same time, started right up idled for a bit then died and wouldnt start back up until I sprayed starter fluid in the carb fired right back up then idled and revved for a bit and died again, It wont stay running starts right up then dies??? now what do you suggest I took the carb back off and sprayed out every passage again with air and carb cleaner, but In my observation the fuel line from the petcock to carb is see through and when it is idling the gas stays at the same level and or bubbles???
It sounds like you've got a restriction or sticking in the float valve (needle and seat, as some call it). Pull and check it. BTW, usually when a noob has carb problems like this, by the time he pulls it 1/2 dozen times, he can do it in his sleep. By the time you get this fixed, you'll be an expert at it.
And yes, make sure those passageways are clear while you're at it. Don't need air, just make sure you can get carb cleaner through.
