HI all,
I have a metro with a crunched front end (before I got it, thankfully). I have a Spree with a bad engine and missing power train bits.
Can I just swap the metro powertrain into the Spree frame? Anyone done this? Is there room? I know I'm going from two stroke fun to four stroke, but maybe the variator can make up for some of the loss. Any suggestions yay or nay would be helpful.
Leon
metropolitan engine transplant into Spree frame?
- SpyderMike
Re: metropolitan engine transplant into Spree frame?
with time, tools and money anythings possible
question is...is it worth it
you wont be able to "just swap" the motors im sure theres going to be alot of straight up fabrication work needed
but if your the type of person that could handle that, i say just give it a try and let us know how it works
I think all you would need to do is re-fabricate the motor mount to fit the metro's motor tabs.
I could be wrong though.
some one already did a ruckus swap into a spree check it out http://totalruckus.com/phpBB3/viewtopic ... 94&t=35185
CH80
Thanks for the quick responses. That spruckus is pretty amazing. I'll have to go over those pics again and then strip the plastic off the bikes and prepare questions.
Odds are a new motor mount will need to be welded, shock mount relocated and a kickstand added as the center stand will most likely need to go. That and some wiring should have it going, spree CDI might work but I would swap in the metro CDI
Why'd anyone wanna do that?! Lose the lovely 2-smoke aroma AND make it even slower...
- burnt_toast
my thoughts exactly, you would get awesome gas mileage though thats for sureWheelman-111 wrote:Greetings:
projects galore
Arnadanoob
2 stroke all the way.
Reliable and dependable tuning from 15+ years of experience.
