Slow Acceleration, other problems
- jeffhardyrules
- BMX
Well I have no power or torque until I hit about 15mph and then it works fine(top speed of 32 mph) and if I have to turn and go 15 mph or slower the blinkers won't blink and just stay lit up. Would it be something with the piston?(because of the low power) Also it won't idle(it is either set to low or too high) I have put on about 75 miles+ since getting it to run better and I decided to check the spark plug which was a reddish brown, so I believe that is another problem. Thanks in advance, yet again.
- eager_beaver
- Goped
- jeffhardyrules
- BMX
- jeffhardyrules
- BMX
Are you running the stock airbox, or a pod?
- jeffhardyrules
- BMX
- Mormonmopedmaifa
- jeffhardyrules
- BMX
- jeffhardyrules
- BMX
- Mormonmopedmaifa
compression would still allow it to go the same speed, just lack power when warm. is it hard to start again when hot?if so its compression.
if not then it could be belt/clutch.
belt could be expanding/slipping
clutch could be fading (like brakes can when hot)
87' spree (SOLD
12' wrx
87' spree (SOLD
12' wrx
