carb(float) help
- jeffhardyrules
- BMX
carb(float) help
i took my carb apart, cleaned it, put it back together and started my 'ped and it started pouring gas, so knowing the float was set up wrong i took it apart again just to find out I have no clue how to make keep the float stay in the spot where i want it to be at. So when I put the carb back together the float is too far open causing gas to still go out(not much just enough to cover the tip of my finger). If I get it set up correctly it will only open/fall when I go to put the carb back on and putting it in place. Just to make it easier I have the pin, needle, and the screw to hold the float in place. When I connect everything the float still is able to move.
- jeffhardyrules
- BMX
- jeffhardyrules
- BMX
- jeffhardyrules
- BMX
You have the patience of God.hondaman wrote:Its a gasket. It goes all along the edge of the carb. When the two halves of carb are put back together it forms a seal to prevent gas from leaking out of your carb.
- jeffhardyrules
- BMX
