Crack in exhaust
deathwish
Crack in exhaust
Post by deathwish »
I got a crack in my exhaust todai(i have no clue how that happend) but anyway it seems alot or the majority of the exhaust is coming out threw this crack...im worried this may lean out my engine and screw it up.. this is my only transportation and i need it fixed so i can get to school tom and im not going to be able to weld it for a while so does any kno of any quick fixes to fix it....thx
vette76
Post by vette76 »
if its just cracked im sure it wouldnt lean it out too much. i just wouldnt drive it forever like that. for now, u can take a thin piece of sheet metal,(really thin) wrap it around the pipe, and hold it with a couple of hose clamps. obviously this isnt a perminent fix, but should get u through the week.
87' spree (SOLD
12' wrx
hondaman
Post by hondaman »
Depending on how wide the crack is you could also try JB weld.
You mix the two tubes together and smear it over the crack. But you have to let it dry at least 12 hours before you start up your spree. It drys really hard almost like metal. Also use sandpaper to clean up the crack before you apply it so you get a good bond.
Justinsane
Post by Justinsane »
do i always need to point out the obvious??? duct tape!
General Spree
burnt_toast
Post by burnt_toast »
hondaman wrote:Depending on how wide the crack is you could also try JB weld.
this is a good idea right here.
also where is the crack located? Try to get to an auto shop with a welder and they should be able to help u.
projects galore :nerd:
darat
Post by darat »
my friend got his welded from a shop here in fraser for 5$
If it's a crack, take it to a local muffler shop and have them weld it.
If it's rusted out, you'll need to get a new one.
It shouldn't have cracked. Are all the attachment bolts in place?
darat
Post by darat »
hey noiseguy u have another spree? when did u get this?
vette76
Post by vette76 »
i tried jb weld on my exhaust, and after a while it just started to crumble off. (from the heat/oil soaked metal i would guess)
87' spree (SOLD
12' wrx
hondaman
Post by hondaman »
Thats why I said you have to sand the area to be repaired first to get all the oil and dirt off. Its also meant to be just a temporary fix until it can be repaired properly.
Yes, by welding it. Honestly, I don't understand all the patching effort. JB Weld runs $5 a package, and a welder will do the job for that.
Yeah, I found another Spree last weekend. This may be my offroader, haven't decided yet (that or the '84). It has lower miles and seems to run stronger, even without mods. I think I'll bolt up the mods I've put together for the '84 to see how they work on it.
deathwish
Post by deathwish »
i think i was riding it around for a bit with two opf the bolts missing and thats how it cracked an dim gonna get it welded in a couple of days
That's what I thought. While you're spending $5 to get it welded, spend another 50 cents and buy 2 more M8 x 25mm bolts. You're lucky you didn't crack the exhaust off at the jug, which we've seen happen here.
I had an expansion chamber snap off at speed once. Same thing, no attachment to the frame. Didn't make that mistake twice.
deathwish
Post by deathwish »
lol yea thank god my frined noticed it because i proboly never would of seen it for a while :lol:
