Yesterday you posted this in Builds:
OK,
I put the new CDI in and I got a 8mph boost with a passenger. I got a 12mph boost with just me
Im putting the 9g weights, the perf. clutch, and the new spring on tomorrow
So what you're saying, if it went 30 for a while, is that your previous top speed was, uhh... 18MPH? And now you're going 20-22? If so you're still ahead of the game!
If not, we can't really help you if you let pride in your accomplishments prevent you from accurately reporting your results.
I believe I cautioned you about changing rollers
and spring at the same time.
I'd also advise caution in changing both the rollers and the spring, unless you're following a proven "recipe" amongst the GY-6 Cognisenti. These are two complementary variables; A stronger spring makes it rev higher and lighter rollers also raise RPM. It can leave a feller right flummoxed if the simultaneous swap kills performance. If you're breaking new ground, consider just swapping one or the other and see if you like it better. The rollers are less work.
It now sounds like your stronger +2000 spring is preventing your lighter rollers from shifting the variator all the way through, leaving you stuck in "second gear". Put your heavier stock weights back in and see if that's enough. If not, get rid of that spring if you can. If your pulleys are wobbly, see if you can get them perfect or replace the assembly.
And let us know what
really happens. The truth shall set you (or at least your scooter...) Free. Lastly, remember you can always...
Dude! Swap in a Dio!!
