First Pics after a quick clean:
I took it home, Some Gumout (The best thing ever invented as far as I am concerned) and cleaned it up a little, and it fired right up.
I did some research, found this great forum, and realized I could put the tire on, with a little moving of the muffler, and got two new tires, tubes, and rim protectors (at cost) 36.00. I went with 10-2.75, but think I will go bigger.
I got ahead of myself, and before doing my research, I ordered a CDI "No Rev Limiter", since found out on this forum, as well as using a digital RPM meter, this did not a thing for RPM.
It runs great, speedo says 32 on a flat surface, but I think that is probably wrong, it actually dropped a little bit after the new tires were on it (but it drove TOTALLY differently), and I assume that will affect the Speedo. I am going to try some run's this weekend with different tire pressures ( I have them at 36 PSI) and see if there is a difference, I am not expecting any huge gains. I am interested in removing the Air Box and going with a K&N that I pulled off a Ski here, I assume I would just need to make an adapter, any thoughts on this?
Basically, I am going to strip it down to frame, except for the middle front fender to keep the wires covered, and do some custom stuff body wise. I will try to fabricate some stuff from Jet Ski's to cover wires and stuff, but I would ultimately like to do a Yellow and Black scheme..Not really into doing too much to the engine, but I have read some stuff on here about porting, and I would like to do some sort of custom exhaust. There are some things in my catalog for off road bikes that I would like to add, including turn signals and headlights that will look pretty cool. I am trying not to go over $200, but it is just for fun anyways so if I do no biggie. I don't expect to sell it an make millions
I also part out Snowmobiles, and I took some Mirrors from a snowmobile and attached them, and took the rear shroud off so far. I am taking all the body off next weekend, so I am will post pictures as I go. I have a guy that works with us that is going to do a custom seat cover for me, no charge, so that will be pretty cool.
SOOOOOO any ideas as I go would be appreciated, and thanks for this AWESOME forum!!!!
