Doffed the stock manifold and carb assembly tonight. From this:
To this:
The designer of the CT manifold evidently wasn't first in his class of industrial design. That rear outside bolt is a pain to install one sixth turn at a time with a chopped-down Allen wrench. This was made even more interesting by a couple of semi-munched case threads - not sure how this happened because the mani evidently had never been removed. Eventually guided all 4 Allen bolts into their tight quarters.
Purchased all the components to fab my own custom cable, as I had done with the CV24 Keihin. You can get all that stuff here:
http://www.dratv.com/mayoowncuthc.html
However my soldering skills suck so bad I couldn't trust those little 3x6mm ends to stay on the 1.5mm cable and gave up tryying. Instead I modded the stock cable to add a half-inch of free pull by cutting off a bit of the casing with a Roto-Zip 1" cutoff wheel. I added a hair too much, so Mik throttle cable opens only 75%. An easier cable adjustment would be nice. I'll have to pull the twist grip to fine-tune.
The pump was plumbed to the manifold port with a T connector for vacuum. Starting up was painless once I remembered it has a manual choke.
Finally can see the new Logo! Looks a lot like Flash!
