MisCarburetin' Spree, Help Please!!!
HI, I am having some major problems with my 1984 Honda Spree. Gas is in my carburator but not past that. I checked my reed valves, everything is good there. I really do not know what to even check any more. Could someone help me please? contact me at jet.man67@yahoo.com thank you for your time!
Re: Help with my spree please!!!
Remove your carburetor and disassemble it. Get a can of carburetor cleaner and clean every part of the inside thoroughly. Remove the main jet and spray spray spray. When you think it is clean do it again.
- bradthreee
hondaman wrote:Remove your carburetor and disassemble it. Get a can of carburetor cleaner and clean every part of the inside thoroughly. Remove the main jet and spray spray spray. When you think it is clean do it again.
Might I also suggest changing the name of your thread to something, that if someone was searching for a problem similar to yours, they might be able to find it.
