air filter?
vette76
air filter?
Post by vette76 »
why does the air filter have to be soaked in oil? i am going to guess it has something to do with restriction?
It's just how they work. The oil catches the dirt and crud. Lawn mowers use a version of this. They're a cheap filter, and cleanable. Make sure to wring out the excess oil.
Jim
Post by Jim »
oil restricts the air that comes in, creating suction, which is needed to pull the gas from the tank to the carb.
86 Honda Spree - Lawn Ornament
83 Suzuki GS450E - Sold
92 Honda CBR600 F2 - Current Daily driver
Spree Repair Guide
Jerry
Post by Jerry »
Minor correction Jim:
Increased vacuum to pull the fuel UP from the bowl into the venturi (Mikuni style).
Note: You don't ALWAYS have to oil the filter. Try it without oil before soaking and wringing out the excess. It may work just fine. Saves a little mess anyway. I'm still deciding if it is really necessary as it contributes to the foam breaking down over time. Of course, at around $4 it isn't that critical to extend the life of the foam anyway.
Scoot safely
Shane4188
Post by Shane4188 »
New Honda Spree Air Filters come presoaked in oil, it would not be necessary to do it again.
backin88
Post by backin88 »
when i got my spree i took the old air filter out because it was trashed/i but a sock in there and have but over 2,000 miles on it, this probably isnt good....
Tippmann98
Post by Tippmann98 »
nonsence, untill filters start to fall apart all you need to do is regular maintence to them. This involves cleaning them and re-oiling them every few hundread miles. they usually last a very long time.
Shane4188
Post by Shane4188 »
I wouldn't wait until they fall apart to replace them. It would somewhat troublesome to clean all that foam out of the carb.
Tippmann98
Yes, what i am saying is that you can use the filter till it falls apart
