starters
starters
does any one know if any other starters fit the nq 50 like the sa for example
Re: starters
The Spree starter mounting plate is different than all SA50 and Aero models. Early Aeros are much different. SB50 has a stamped steel mounting plate.
I'd stick with the Spree starter. Internal parts exchange is possible with some, but the Spree is the common and low cost starter.
- Spree_vs_SA50_starter.JPG (9.97 KiB) Viewed 3667 times
Re: starters
Well it might be common but if you can can find a honda shop that has one they list for over 150$ is there a better source? e- bay has a limited # ever posted and there's no way to really know if its a pos.
- bradthreee
Re: starters
Sorry - was thinking on the used side for 'common'. And with that comes the occasional bad one - I have experience with that too..Well it might be common but if you can can find a honda shop that has one they list for over 150$ is there a better source? e- bay has a limited # ever posted and there's no way to really know if its a pos.
Anyone else tried looking at other scooters and small cycles for a Mitsuba starter equivalent? I spent some time looking at various Japanese scooters, cycles and ATV's for equivalents. Only starters found are the knock offs for the 88-93 SA50 on eBay.
Re: starters
anyone have a starter for a 96+Elite/SA50 ?
busting my knuckles on vices since
for long as i can remember
