engine removal
nwaman22250
engine removal
Post by nwaman22250 »
i have a 99 elite sr and was wondering if anyone can tell me what size socket i need to remove the engind its just the swing are bolt and the shock that hold the motor in place correct
thanks
Re: engine removal
12, 14 and 17mm should remove the shock and engine mounting bracket bolt. The shock uses a 12 on the bottom and either a 14 or a 17 at the top. The engine pivot also has different-sized heads on the bolt and larger nut.
A 7/8 SAE socket fits the rear wheel nut very nicely. Methinks 22 if your're a Metric Purist.
mookie
Re: engine removal
Post by mookie »
shame on you Wheelman for even mentioning SAE.
busting my knuckles on vices since
for long as i can remember
