What is a Pod filter?
bigbuickgs
Post by bigbuickgs »
I guess that is it. What is a pod filter. I have a chrome v-8 breather with a piece of 1-1/4 heater hose to connect it to the carb. I havent put it on yet because with when I was trying things out I discovered that the engine just dies when you hit the gas w/o the stock air box. What size main jet should I start out with to try this.
burnt_toast
Post by burnt_toast »
these are unifilters:
http://www.unifilter.com/clamp-on.htm
and pod filters are gauge wire filters, like K&N's.
projects galore :nerd:
vette76
Post by vette76 »
stock jet size it #65
87' spree (SOLD
12' wrx
Guys that claim to have gotten it to work usually run #80 - #90 jets.
vette76
Post by vette76 »
i hav found, when running a hi-flow filter, you lose some of the "snap" from bottom end.
87' spree (SOLD
12' wrx
Totally. It has to do with the design of the airbox. I've been so unimpressed by them I've quit messing with them for a time. If you can connect a piece of hose to the carb, lengthening the intake tract, it helps the scoot draw air better at lower RPM. The airbox volume helps the scoot draw air better at a variety of RPMs, rather than just being optimized for one.
maddog
Post by maddog »
for a stock engine don't even bother, i only use them on engines above 82cc and hope it doesn't rain!
Yeah, I think at that point you can actually use the airflow. Either way, you'd be running a larger carb that won't fit the stock airbox tube. I wonder, though, if you created a larger tube to the stock airbox and opened up those little airbox inlets by the same amount you bumped up the carb, if you wouldn't get a better running scoot that could run with a smaller main jet.
Some guys have posted positive results with stock displacements and pods, though, so I haven't completely written them off.
bitteraspects
Post by bitteraspects »
kuka makes tubes with the oversized lip opening to fit on a bigger carb.
hrnytrtlsgsxr
Post by hrnytrtlsgsxr »
bitteraspects wrote:kuka makes tubes with the oversized lip opening to fit on a bigger carb.
then you could get them at VT I presume.
hrnytrtlsgsxr
maddog wrote:for a stock engine don't even bother, i only use them on engines above 82cc and hope it doesn't rain!
At 72cc you could use a DDx airbox but they are hard to comeby. Most guys in the 808 use the pods,uni or nothing at all.
sulfuraciddd
Post by sulfuraciddd »
or velocity stacks like me
bitteraspects
hahahah. why eould you say that???
:lol:
but yes, they used to carry it, i believe there are still some there. i used one to adapt my stock sym dio50 airbox to a 28 oko carb
MySpree
Post by MySpree »
i have found when running a pod filter on a spree. it good to have a velocity stack on... but its more effective when you have a velocity stack.
darat
Post by darat »
i want to get the photoshop
