Bystarter testing quesiton
bradmeehan
Post by bradmeehan »
To measure the length of the needle travel on the bystarter I read that you can put the leads across 12vdc and check after 10 minutes or so. But...my bystarter has a plastic quick-connect at the end so the leads are not exposed to do this test. Should I just jam some wire in there? Or is there another point to disconnect? Do the wires pop out of that connector?
1986 Spree
1986 Spree (Big Bore)
1985 Aero 50
1985 Aero 80
1988 Elite 50 (SB50)
1985 "OrangeJuice" (Sold)
Alarmnbob
Re: Bystarter testing quesiton
Post by Alarmnbob »
Forgive me, But I am going to ask a stupid question. :jack:
Are you having problems starting the bike or keeping it running when cold?
To answer your question- Yes you can just put power to it.
86 Honda Helix, 1995 Honda Helix, 2004 Helix Clone
87 Honda Elite 150, 88 Elite ES , 1999 Itajet Dragster
86 Honda Aero 125 , 2004 Honda Elite 80
2002 Yamaha Vino"ROCKET"
bradmeehan
Idle when cold is the issue. It'll stay running if i hold the throttle open a bit. Once it's warmed up, it sits and idles great.
1986 Spree
1985 Aero 50
1985 Aero 80
Alarmnbob
Post by Alarmnbob »
How does the opening look when you remove the bystarter valve. Is it clean? I would flush this out with a little fuel or carb cleaner.
You just want to see that it gets longer when energized.
bradmeehan
I cleaned the heck out of it when I did my carb cleaning. I swapped out the carb on that bike when i found that the tube next to the main jet was kinked from the previous owner trying to pull it out with pliers.
One thing to note is that tube that the needle rests in was out when I opened the replacement carb to clean it. I cleaned and re-seated it. I wonder if it's not seated all the way in? (or pushed in too much)?
1986 Spree
1985 Aero 50
1985 Aero 80
Alarmnbob
Post by Alarmnbob »
Brad,
Remove the screws and lift the choke slightly out of the carb while you crank the engine. If it starts the carb is ok, by-starter is bad.
I live in Kansas City. I will for the most part be out of town until Halloween, but willing to lend a hand and do some riding.
I have about 15 spree's so if you need parts I probably have them. NO CARBS OR BYSTARTERS though.
bradmeehan
There are a few others from KC on here as well!
It starts, it just doesn't idle until it's warmed up. Would that test still confirm that?
1986 Spree
1985 Aero 50
1985 Aero 80
Alarmnbob
Post by Alarmnbob »
The bystarter is only a choke to help it start.
Alarmnbob wrote:The bystarter is only a choke to help it start.
Not quite true. The bystarter is an automatic choke that until the heater in the bystarter warms up the fuel mixture is enriched. The enrichment helps the cold idle.
