Backpressure
Mormonmopedmaifa
Backpressure
Post by Mormonmopedmaifa »
I was thinkin about drilling out my tailpipe but i saw that it relieves axhuast pressure and i know that is crucial for it to run..... but uhh what exactly is backpressure and why does an engine need it?
M>M<M
THE MAFIA STRIKES AGAIN!!!
ALMOST running spree!!!
darat
Post by darat »
i think back pressure helps with the compression which makes the pistion go up and down if u dont have enough then it wont make the most HP.
That is my guess
Mormonmopedmaifa
no im pretty sure people say engines NEED it ( 2 strokes) to run .
M>M<M
2-strokes are greatly aided by properly designed pipes that acoustically "echo" at the right frequencies. This effectively plugs the exhaust port while the piston is coming back up. All this is more technical/engineering knowledge than most ppl care to pick up, but here's more:
http://www.motorcycle.com/mo/mcnuts/em-pipes.html
Bottom line: Just drill the 4 holes, you'll be fine. Do a search in this section and you'll find an expansion chamber that I built which worked pretty well also.
Admin, Hondaspree.net
Mormonmopedmaifa
And what if i drilled 5 holes?? just kidding thanks for the explanation
M>M<M
darat
Post by darat »
how did u make ur icon like that?
Mormonmopedmaifa
I used a .gif file. i think they can have like up to 7 frames or sumthin and stay under 10 k if theyre small
M>M<M
darat
Post by darat »
no i am saying how did u get them to change like that did u use a program?
Mormonmopedmaifa
yeah its just a .gif . u can make em in flash and fireworks and probly photoshop.
M>M<M
