Sym dd w/ hona dio engine i need help please!
Mystic
Re: Sym dd w/ hona dio engine i need help please!
Post by Mystic »
yea that will work thats the throttle cable i use :D good seller too
jacob789
Post by jacob789 »
sweet thanks my one * froze cos its been snowing n ive broke it while i was tryna open it
jacob789
Post by jacob789 »
oh no they dont deliver to uk does anyone know anyone tht sells a single wire throttle cable n delivers to uk?
Mystic
Post by Mystic »
have you checked jiangwayne.com?
http://www.jiangwayne.com/scooter/p_i.php?i=354
Mystic
Post by Mystic »
jiangwayne is steep though, i checked on ebay and that cable you found from autotech335 does ship to the UK
--you can also email the guy at scooterassasins and ask him about the cable cause he does sell a 24mm oko kit so surely he will sell a throttle cable seperately http://www.exportstrength.com/index.php ... _5425_5427
jacob789
Post by jacob789 »
dont worry panics over haha yh i just found out they do deliver to uk, i have to go on ebay uk and type it in though, if i do it on ebay.com when i go to the delivery bit UK isnt a choice. i have e-mailed the guy from scooter assassins earlier but ill probly go for the one on ebay if i need to get a new one. hopefully my ones repairable. is it possible to stretch a throttle cable? i kept pulling it when it was stuck and i think ive damaged it.
thanku
jacob789
Post by jacob789 »
also do u know if an unrestricted cdi will change my top speed much? normally i get around 55-60mph but ive had 65mph on a flat
Sym DD
72cc Polini Corsa
Tecnigas Next R exhaust
OKO 21mm carb
CT intake manifold
7.4:1 gearing
Koso variator w/9g rollers
Race clutch w/2000 rpm clutch springs
Bando racing belt
60+mph
Mystic
Post by Mystic »
I dont think the cdi is restricted on your scoot and if the cable isnt actually broken inside the plastic housing i dont see why it doesnt work. have you taken the carb top off to see if it just came loose?
jacob789
Post by jacob789 »
ok and no i havent im probly gona take it to the garage tomoro. it does work but not properly, it gets stuck, sometimes gets stuck whilst its revving lol, its harder to pull back and doesn't just flip back quickly as soon as u let go how it should do. wld it be hard to put back together if i took the carb top off? and cldnt i tell just from pulling the throttle on the bit where it comes out the carb? because tht works fine when i do tht
jacob789
Post by jacob789 »
it is broken i need to get a new cable :x Arent all the stock cdi's restricted? because my cdi is definitely a stock one
Post by swimmingfree »
the ones in the use are not don't no about there..
swinningfree
ps do you do what your max rpm are???
jacob789
Post by jacob789 »
ok was that meant to say do you know what your max rpm is? if it is then no
yes thats what i meant..
if you had that info it wood tell you if it was restricted.. not sure but here in the usa they do about 8.000 to 8.500 rpms ..
jacob789
Post by jacob789 »
ok yh tht probly is roughly what mine does judging from the sound, the gear-up kit lowered the rpm, do u mean 8000-8500 on an unrestricted cdi?
jacob789
Post by jacob789 »
ive ordered a throttle cable off scooter assassins now, i e-mailed the guy about selling me one privately and then he put it up on the website for £11.50 so if anyone needs one probly best to get it off thr
