Getting pretty irritated.....
Re: Getting pretty irritated.....
So I'm pretty sure its running rich. It seems to bog a little between 1/4 throttle and half, and then after half to wot it bogs BAD, loses speed and a lot of temp
Loses a lot of temp
- swimmingfree
this may help you set the carb... you need to no what the plug looks like if you guess wrong you can fry the motor..
By freeswimming at 2012-03-31
If it is actually too rich in the mid-range. raise the clip on the needle. If it was me, I would run it for 30 seconds or so right where it was missing and then do a plug chop and confirm it was rich. Too lean will cause the same issue.JustynCRX wrote:So I'm pretty sure its running rich. It seems to bog a little between 1/4 throttle and half, and then after half to wot it bogs BAD, loses speed and a lot of temp
Plug chop pics in a couple minutes....
Down jet to 40 pilot and 108 main.
This was from a WOT run 1/4 mile out and back then hit the kill switch
Did one more run on the same plug, and same settings took it out a little over half a mile out and back temps almost got to 270.
- fastplastic
by rights each plug chop should be a new plug but idk if i would call that too rich.....
Agreed.fastplastic wrote:by rights each plug chop should be a new plug but idk if i would call that too rich.....
I figured if the settings are the same the using the same plug would be fine. I just wanted to run it a little longer to maybe get a better reading.
Agreed rich or agreed bad chop?
- fastplastic
not rich and bad chop...
So lean then? Up jet or move the clip?
- fastplastic
i want you setup from top to bottom i dont feel like reading 8 pages..
like
block
bore
carb
exhaust
jet (that gave you the plug color)
air box
tell me about all of these then i can help more
like
block
bore
carb
exhaust
air box
AF05 87 SE50
Malossi MHR
Stock deristricted exhaust
CT Chrome, 21mm OKO, pod filter.
40 pilot, 108 main
BPR8HS Plug
Koso variator, 9g weights.
Malossi MHR
40 pilot, 108 main
BPR8HS Plug
