SE50 build
Re: winter build
Post by swimmingfree »
im looking for some info for setting the carb using the temp Gage.... the best temp is between 350 and 400 .... is this wright????
curtis966
Re: winter build
Post by curtis966 »
Prolly won't be to far off with the 107/48 if it's Idling smooth gotta be close. I'm running a 110/42 in my 21 oko on 65cc polini af05. Bit mines not fully dialed in yet either. When I did my heat cycles I did about 4 to 150-200 degrees and about 4 to 300 degrees and 4-5 to 380-400. Took her easy for about 60 miles and then started crackin it open here an there. Just watch your temps once you start actually ridding it. Prolly over kill but better safe then sorry. Running temps can be anything up to 350-400 just gotta watch the great spike after running wot. Took the polini to 430 degrees a couple times no problems but I'm running 100 octane fuel.
Re: winter build
grate info today weather in muskegon is going to be about 45 or so ... im thinking ill get the tire fix and do a slow run on it ... were do you live in Michigan??
Re: winter build
21mm oko carb 7 gram rollers Malossi jug putting new piston and rings 107 48 in the carb used yellow Malossi spring and 3 green Polini 2k grabber springs..
hope that helps .... got the tire fix took it for a short run not impressed its a dog as it set now its running rich ... pull the plug it was dark brown the temp gage got to 230 never got inny higher... the temp out side was in the mid 50 ... its going be cold out today so will not be trying inn thing today.. i think the air screw is set at 1 3/4 and the pin is in the middle.. setting the carb is a pain in the but... i think im going to try the 42 maim jet and see how it works... i may drop the pin by one after i run it with the 42 main ...
like to no if im doing this right fist time with a oko carb????
paulpauly7
Re: winter build
Post by paulpauly7 »
yes your doing fine .Id try the 42 and 102 remember its only 65cc and you now have a ported block.the bigger those intake windows in the block the smaller jets you need .Air speed from the carb to the jug changes jetting
Re: winter build
paulpauly7 will do today if the weather get nice out ...going to do the main jet first then the slow jet then clip position ...... or some other order???
bonesv
Re: winter build
Post by bonesv »
http://scootrs.com/tech.cfm?tip=tunecarb
Please take this refresher course. It will make everything clear for you. Good tuning!
Re: winter build
will do ...thank you....
Re: winter build
just got done reading it ... as well as listing to it... (Natural Reader text to speech software ) bu what i have read it running rich all the way a round ... dose not say a thing about a temp Gage on tuning the carb ... the temp at idle is about 160 and on a ride at 3/4 it get to about 256 so its running cold to munch gas running in the mix ???? i think???
bonesv
Re: winter build
Post by bonesv »
Ok, just remember you are still breaking it in. just take it easy with it and read the plug . keep an eye on the temps so it doesn't get over 400 and let it seat the rings. Rich is better than lean, you know that. You will get to tune it as you go. The main thing about the temps is that you get familiar with the engine and where it runs best at, and how performance acts as you change the settings; i.e. plugs; br6hs to a br8hs, or jets, or needle clip setting, or fuel to oil ratio. Do you have a tachometer? Learn, have fun and be careful during break-in. Give it the time it needs to "run-in". Keep us posted and enjoy the nice weather you have waited so long for!
Re: winter build
21mm oko carb 7 gram rollers Malossi jug putting new piston and rings 107 42 in the carb used yellow Malossi spring and 3 green Polini 2k grabber springs..
put in the 103 42 jets ...my tack off suck big time so went back to the 107 jet and kept the 42 jet.... the temp never got over 300 as of yet and i went for a ride of a fue miles our tenp was 55 ... did not drop the pin its still in the middle grove ... did open it up for a short time and it did not go over 7800 rpm. and that what i get with the stock carb.... and the speed was about 40 mph... i wood like to no how you guys can get like 9000 or higher rpm out of your scooter???? i pull the old rollers that are 6 grams out of the old motor to try but thay have flat spots on them so did not try them ...
like to no what you guys do???
swimmingfree wrote: but still like to no if i shood keep this peace of spring steel on the reads or not???? i feel it will hold back the rpm ...
swimmingfree wrote: Image
paulpauly7
Re: winter build
you need lighter rollers.What exhaust are you using?
Re: winter build
paulpauly7 im running 7 now what do you think i shood be running... as for the pipe im running a stock pipe that has been gutted and a bigger tip put in ..i think is 1/2 id pipe because the tip and end was crush..
heres how it ran yesterday... tack off is good and strong till i get to about hafway in to it then it sound like a vacuum cleaner and has no guts at all .. need to do a plug crop at the hafway spot and see if its running rich or leen and move pin in the right way...
curtis966
Re: winter build
Post by curtis966 »
I have a total of 33 grams in my variator I think. I get her spinnin in the mid 9k range. I think the pipe is hurting you more than helping you.
Re: winter build
chopchop*123 has 6 grams rollers on ebay that wood be 36 instead of 42.. need to get to a long strate way to do a plug crop .... i thing the pin need to be moved ...
http://www.ebay.com/itm/Honda-SA50-SE50 ... 5653b83ca1
