still cuts/bogs out
55bore
Post by 55bore »
If you're running your air-cleaner, take it off and see if that fixes it.
If you have access to another carb (probably not), then just swap the carb and see if that fixes it.
Or, try replacing your needle jet and needle jet retainer. It's pretty easy to change them, and you want to do it every so many years anyway since they will wear out over time.
Post by Kenny_McCormic »
He already plug chopped it its running a good f/a mix.
wayalive
Post by wayalive »
Same EXACT problem here with a 1985 spree. Jams on the centerstand and for a few minutes under load, but then bogs and stalls. Does feel like it's fuel starved, but only when it has a passenger on it.
I'm wondering if this could be cdi related (about all that's left to check)... But I don't really see how bad spark or timing from the cdi would cause bad performance ONLY under load.
Any new ideas?
Spiderlad
Post by Spiderlad »
Ack!!! did you end up finding out what was wrong, Iv been useing this thred as a refrence and it just stoped :shock:
Guns Dont Kill People Doorknobs Do!!!
RenoScootSquad
Machinac -1
Well, this is a long thread, and there's a couple different scooters involved.
Here's an idea for wayalive:
[quote]Same EXACT problem here with a 1985 spree. Jams on the centerstand and for a few minutes under load, but then bogs and stalls. Does feel like it's fuel starved, but only when it has a passenger on it.[/quote]
Check the fuel flow from the petcock, with a vacuum applied and hose disconnected. If just drips and not a dribble, clean the tank strainer and petcock.
Seth81
Post by Seth81 »
Guys i also have the same problem with my 85 spree. I did however have a spare carb from an 84. Unfortunately it helped nothing. Hard starting, wont idle, cut out at 15mph. Will idle high for a while then stop. runs good once in a while at high idle. These dang sprees are the most frustrating machine i have ever worked on. I am no expert but i am not an idiot either. Man im pulling my hair out. I have all kinds of parts, and also an 84 that i just bought that is so hard to turn over with a spark plug in it, or even with my thumb over the hole, Arrrrrrghhhh
Seth81
Post by Seth81 »
Just take it to a honda dealer. I think i am gonna. 60 bucks an hour is a buttload of money, but at least your dealing with a certified technician. I'm just so fed up. :-(
