Hehe, guilty as charged.bakaracer wrote:put an airbox and down jet for the airbox. Oh and try and not grab a whole lot of throttle when stop and go riding.
I'm going to have to nurse the throttle a bit more these days.
I'll buy that for a $1sanjuro wrote:Kind of a crappy middle of the afternoon shot:
Sometimes the needle position has to be moved to fine tune the throttle response.If it feels like its a bit rich when you first grab throttle the move the clip up one to lean the needle out a little.sanjuro wrote:I'm assuming the weld spot should be on the topside of the header? Can you post a pic of the ideal spot?
The needle is set at the stock position, and I haven't touched it. Ideally, I want to get this thing dialed in without having to do any adjustment to the needle position. I'll adjust it if things are out of whack, but so far things seem to be really smooth. If the temperature reading isn't crazy off, I'd like to get some more refining done of the jet size first.
I'll find out this afternoon, hopefully.bakaracer wrote:...did you get a 90deg angled sensor or the straight?
