Checkin in, first post... here at least
Chicago Ben
Re: Checkin in, first post... here at least
Post by Chicago Ben »
I bet there is 0 difference between the 10 section and 13 section in the actual 'mufler' part
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
1000k Polini triples
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
A few pictures
Chicago Ben
awesome man! Looks good so far! Thanks for the pictures! What are your takes on the overall condition of the engine at approx 5000 miles later?
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
not bad for 5000 miles
One of the bearings stuck to the crank....had to get it off with the bearing puller :x
Chicago Ben
Trafficjamz wrote:not bad for 5000 miles
I see that. That sucks. How brittle do you think that 52mm bbk is? I hope we (you) aren't building a bomb!
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
I would get a CHT for sure :wink:
Chicago Ben
Trafficjamz wrote:I would get a CHT for sure :wink:
Ok just ordered the trail tech temp gauge from treatland, this should do justice
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
just pulled the trigger on a smoked kymco tail from vt
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Post by eliteguy50 »
Chicago Ben wrote:I bet there is 0 difference between the 10 section and 13 section in the actual 'mufler' part
I wouldn't go that far, but I would bet that none of our scoots are tuned to the point of noticing the difference.
fastplastic
Post by fastplastic »
umm there is a big difference.....
fastplastic
fastplastic wrote:umm there is a big difference.....
Such as?
Chicago Ben
There are more welds
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben wrote:There are more welds
You got me there Ben. :hi:
Such as?
Oh yes there is a huge difference :smile:
That is the reason I want to find one of these 13 section pipes :wink:
It took Fastplastics ride from mild to wild when paired with a 28mm carb :shock:
At first glance these two pipes seem to be the same, but if you bring out the tape measure, you will see the are indeed different.
