89 Elite R - my first build
89eliteR
Re: 89 Elite R - my first build
Post by 89eliteR »
eliteguy50 wrote:
89eliteR wrote:Now this was kind of touched on before, but im going to fork down some golds today for one. First mod that was suggested to me on here was the ruckus vari. What year ruckus vari would be the best on the AF05e? Im heading to the honda dealership to get one, along with a replacement belt.
So what year of ruckus vari is best? and besides the big gear looking thing, do i need to keep my ramp plate? or does that whole thing get replaced?
Only the movable drive face, ramp plate, and slides get replaced. The roller size is the same as your af05 but the weight will depend on your build.
The nps50 variator is the same for all years. It is the Metro vari that has differences.
awesome man. I guess to dumb it down further, If I got a ruckus variator, I would have all the parts mentioned. Just add my big gear part when i reassemble.
89eliteR
Post by 89eliteR »
just about to install the bore kit. i got 2 head gaskets to lower compression during the break in. just need to know which way they go.
is it this way
or is it this way
dun rite
Post by dun rite »
not sure that it matters. I put the bump up.
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
89eliteR
Post by 89eliteR »
HOW THE f*** CAN I GET THE CIRCLIPS IN!!! :evil: :evil: :evil: :evil: :evil: :evil: :evil:
dun rite
Post by dun rite »
squeeze them gently with needle nose pliers, or start one side in the hole a little, press on it with a screwdriver and work around till its totally in the hole then use the old wrist pin to push it into the groove. make sure both of them go into the grooves, and align the gap of the circlip with the bottom of the piston.
arreche air filter
v8 pipe
stock gears
89eliteR
Post by 89eliteR »
ok last piece of the puzzle. i wanna make sure i dont donkey this one. do i got the head right before i bolt this down?
exahust port is below my thumb
dun rite
Post by dun rite »
the 89 manual shows a different head with diagonal fins, the 87 manual shows a head like yours with it placed like your picture. Interesting???
arreche air filter
v8 pipe
stock gears
Post by eliteguy50 »
Looks right to me. Full length fins on the fan side and short fins on the drive side.
se50 has different porting than the 89 and the part numbers are different to back it up.
89eliteR
Post by 89eliteR »
i have a Canadian 89, to its the same as the 87 se50 in the states
eliteguy50 wrote:Looks right to me. Full length fins on the fan side and short fins on the drive side.
The '89 I am writing about is the sa50.
89eliteR wrote:awesome man. I guess to dumb it down further, If I got a ruckus variator, I would have all the parts mentioned. Just add my big gear part when i reassemble.
The variator is only the movable drive face. Honda USA does not sell it as an assembly so I doubt Honda Canada would. I don't know what you mean by "big gear part."
89eliteR
Post by 89eliteR »
does the head gasket go like this? i notice some bends so wanna make sure i dont mess it up
niftyman
Post by niftyman »
You should get that head done to match the new size piston
DJ1
NEK MINNIT
Malossi
DJ1 54mph
dio gear swap in progress
living in chch NZ
earthquake central
tazland001
Post by tazland001 »
True that. If that head is not done you will have piston smack on the head. Either get the head done or use two base gaskets. If it was me I would get the head done.
Taz
niftyman
Post by niftyman »
Does the base gasket that came with the bbk match up with the ports on the case i only ask because the R model has different porting compaired to the non R most of the bore kits i have seen that are for the se50 afo5e will NOT fit on the R block
DJ1
NEK MINNIT
Malossi
DJ1 54mph
living in chch NZ
earthquake central
