soft seize?
Re: soft seize?
do you think it would help if i moved the needle clip up a notch or 2?
TJ
TJ
- swimmingfree
Re: soft seize?
the pin should be set as stock .. on the middle slot as well as the rest of the carb ..
Re: soft seize?
swimmingfree wrote:the pin should be set as stock .. on the middle slot as well as the rest of the carb ..
will do. thanks
TJ
Re: soft seize?
When your cranking the motor,cover the mouth of the carb with your hand. If the compression is good and the case is not leaking, suction will be strong. If the carb is getting fuel you will also get fuel to spit on your hand when you cover the carb while cranking the engine over too. That one way of also priming the carb if you took the carb bowl off and no fuel was in there.
Re: soft seize?
The also is the bystarter plugged in? If it is then that might be faulty.
Re: soft seize?
forget it. i give up. she wont start. heck she wont even turn over w/ the electric start. all it does it click. some sensor near the battery clicks when i push the start button...
does anyone want to buy a scooter. i'm done!
TJ
TJ
- kingkamehameha
Re: soft seize?
kingkamehameha wrote:Sell me your motor.
I'll sell ya the whole darn thing. how much will you give me for it?
TJ
- kingkamehameha
Re: soft seize?
eh just take a break from it for a little bit then go back after you do some research etc no sense in giving up after all the work you have already done.
- swimmingfree
Re: soft seize?
i find aftre a day like your having Mr. Kessler helps
im having one for you now or 3
now it may help if you put up
compresino is?
spark is ??? week blue red ????
the carb is set at ????
new or old plug ??? the gap is set at ???
the air flter is ???
and inny thing elce thay may help us help you ..
we can do this
compresino is?
we can do this
Re: soft seize?
swimmingfree wrote:i find aftre a day like your having Mr. Kessler helpsim having one for you now or 3
compresino is?
we can do this
i'm breaking out the mason jar tonight. good ol clear water.
compression is 127
spark is blue
new plug
pod air filter
carb is at factory setting
TJ
Re: soft seize?
some clear water for a bad day... not much left after the day i had.
- 0228122114.jpg (42.76 KiB) Viewed 6870 times
- swimmingfree
Re: soft seize?
rimber if you drink the good you pi sss beer ..
that dont look clear to me ??
Re: soft seize?
used to be clear till the berries got added.swimmingfree wrote:rimber if you drink the good you pi sss beer ..
