Right now, I'm okay with only 55 mph with an unported cast iron since most of the roads I like to travel involve a lot of twisties.bakaracer wrote:if you try and get the elite s gears and get your gear ratio to 9to1 your topend will be better and not loose that low to midrange you like.that 8.25to1 gears,what was the teeth count on those gears?
I was using the Dio ZX 13 tooth primary drive shaft along with the 41 tooth countershaft (the large cog). So 13 x 41 for the primary gears.
The above was used in conjunction with the 9:1 secondary gears from vtcycles. The pressed on cog for the final drive shaft had 42 teeth and the countershaft (smaller spindle) had 16 teeth. So 42 x 16 for the secondary gears.
I only hit 51 mph with that setup since I didn't have the power to 'pull' the gears.
So, is 55 mph 'normal' for a Malossi unported cylinder with PG Typhoon pipe?
